Loud rattle noise from Roborock S50
i bought a used roborock s50 but it has a loud rattling noise that probably comes from the main brush.
Does anyone have any advice on how to get rid of it? I have already cleaned it thoroughly.
Thanks a lot and best,
Moritz
  • Hello Moritz,
    Thanks for your info.
    Try to uninstall the main brush and start the robot to verify whether the noise issue still persists.
    Also, you can send us a short video of this abnormal sound for reference.
    mowsn
    mowsn09/23/2020      06:09
    Thanks for your fast answer - i will try to uninstall the main brush later to detect the noise issue.
    Here is video from my roborock with the loud noise: https://youtu.be/bF7Bj9OEAuY
    Thanks for your help!
    mowsn
    mowsn09/23/2020      08:27
    I checked it and i‘m pretty sure the reason for the noise is the main brush housing hanging to low. So the cover of the main brush will rub on the floor. Just without the main brush but with the „main brush cover“ on it, the noise does not disappear. As soon as i uninstall also the cover of the main brush, the noise is gone.
    Do you have a recommondation how to fix it? Where are the springs for the main brush unit?
    thanks a lot!
    RR_SupportStaff Member09/25/2020      06:35
    @mowsn:
    As my knowledge, it seems normal, due to the floor is clean, there is a chance that the main brush cover will touch the floor directly. You can keep using it for a few days and then it will be fine. Or you can put some powder on it and verify whether it helps.
mowsn
