Roborock S4 Max, an extension of S4 vacuuming cleaning experience
Hello, Roborock fans
Roborock S4 Max is here, the top product of the S4 line. 🤩
This model introduces a much better carpet cleaning capability based on S4. To be more exactly, Automatic Carpet Boost can instantly ramp suction power to a maximum of 2000Pa when a carpet is detected. A better threshold climbing enables it to tackle any surface of up to 2 cm, more easily to create a through and convenient cleaning route.
As for its software upgrades, Multi-level mapping feature allows your robot to automatically recognize different levels with its own set of No-Go Zones and No-Mop zones for a more finer control over its location. Meanwhile, Room sequence cleaning helps you customize what the sequence you want your rooms cleaned, even schedule a specific time for cleaning each room.
Roborock S4 Max aims to provide an effective and smart cleaning solution both on floor and carpet. 😏
Keep following us to find out more!
RR_News
