HELP PLEASE
Hello, good luck. Please help me. As it can be seen in the image, the top side of the leader sensor is slightly damaged when passing between the items, so I mean, will it be worse in the next cleaning, will it be damaged, will it hit more, what precautions should I take on that side?
Sabrinyo
